Question Bluesound Node 2 question
jonnybee123
Quick question to any Bluesound Node 2 owners out there.
The optical in socket at the back of the unit. How is it switched to route out to the main RCA outputs?
I assume its switched? . Im thinking of connecting my TV via toslink to this input socket and use the node as a dac as well as streaming.
(im looking to buy one 2nd hand)
Thanks.
Cold blooded
The source input for optical (TV) is selected through the BluOS control app on your Android/IOS Phone or computer
jonnybee123
It would have been nice if it was a physical switch on the unit or switchable by a remote control. For ease of use it looks like ill have to buy a cheapie dac from Amazon just for the tv. Thanks, thats very helpful. :thumbsup:
keylion
You can program an infrared remote control to work with the node. I've never used this facility myself but the option for optical input is there in the menu.
jonnybee123
So do you think I can buy any IR learning remote and programme it for the bluesound.?
jonnybee123
