BlueRay question...
Discussion in 'Plasma TVs Forum' started by LRk, Oct 27, 2004.
  1. LRk
    LRk
    May 24, 2004
    Thanks to the advice from this forum i've not long bought a panasonic th-42pe30 with which i'm well pleased. :clap:
    But I was wondering,how will Blue-Ray dvd's play on a sd plasma screen with the resolution of the pe30?.Will the better resolution on the disc be apparent on screen or would I need a Hi-Def plasma (I love my shiny new telly and I'll be :censored: if Im buying a new one anytime soon.)
    I'd be much relieved if someone could put my mind at ease
    :lease:
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Unfortunately your PE30 doesn't accept 720p signals and hasn't got a DVI or HDMI input either. Sky HD boxes may only output HD from an HDMI connector - HD component outputs are not guaranteed, although they would lose a lot of potential customers for their service if they didn't fit them. Hopefully, you would be also be able to select a suitable output resolution such as 1080i for your display, like US STBs allow. Blu-ray and HD DVD will be only HD from HDMI - definitely not from component. Hope this helps.
    Steve
  3. gammmmo
    gammmmo
    May 20, 2003
    391
    +12
    "Blu-ray and HD DVD will be only HD from HDMI - definitely not from component"
    If this is true it would play a pretty major role in my choice of plasma. Are Jap blu-ray players only HDMI?
  4. Todda
    Todda
    Can I ask where you have taken this quote from please.
  5. gammmmo
    gammmmo
    May 20, 2003
    391
    +12
    Yeah, the post directly above the one I made...
  6. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    It is possible that HD Sat receivers, such as $ky, will also have the same constraints for CP material - films etc. In other countries, when the CP flag is set, its SD only via component and some broadcasters have bowed to pressure from the filmmakers and have started doing this.
  7. Todda
    Todda
    Sorry. I was showing my intellegence there.
  8. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Current DVD licensing doesn't even allow upscaled SD material to be output over component, although some Chinese manufacturers don't play by the rules! On that basis I can't see them allowing unencryted analogue 1080p out of component for HD DVD, or the BDA allowing Blu-ray players to output the same.
    Steve
