Blue Yeti X Mic & Logitech G Hub / Logitech Capture
voodoo 5
Hi all,
I've just got a Blue Yeti X microphone and downloaded the Logitech G Hub software so that I can adjust some of the voice tones I'm getting through the mic. When I'm doing the voice tests on G Hub, it's working fine and I've managed to get the right voice tone that I want to use. (It took me a long, long time to get the G Hub downloaded properly and to get the microphone detected... I initially tried the Blue Sherpa software, but thats another story).
However when I go onto my webcam, using the Logitech Capture software and select the Yeti X as the audio input, it doesn't seem to be using the voice tones. I think it's just using the mic with no filtering. Is there something I need to do to "enable" the G Hub software? I'm not seeing another option within Device Manager to select it as an audio input...
Any help getting this setup would be fantastic!
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
