Quantcast
Blue tube image problems !!
cosmic023
Hi All,
My blue tube seems to have an image which is bigger than the phosphor area ??
The green & red are centered, and are winthin tolerances of the phosphor edge. Why would the blue increase in size ?? Because i found it almost impossible to converge the blue image, and have to wind everything to the extremes and it's still not lined up properly ??
I just don't understand it, as it was ok before ?? The only thing i did was rotate the blue yoke to level the image.
Have i disturbed something else in the PJ ?? Becasue the blue image is bigger than red & green images ??
What can i do to reduce the blue image, so everything is ok again ??
Cosmic023
rob12770
I know its an obvious to suggest, but r u sure you havent moved one of the other rings whille adjusting the yoke ?
cosmic023
Hi Rob,
What rings ??
I haven't ventured very far inside this thing, just rotated the blue yoke today. Blinkin' scary with 36kv+ floatin' around.......been putting it off for ages.
Cosmic
EDIT:
Sorry misread your post Rob, haven't touched any of the pole rings at the back, would they move that easily ??
If so which one do i use to reduce the size of the blue image ??
(The blue image is currently about 2-3mm bigger than the red & green images, and bigger than the phosphor edge !!)
rob12770
I dont know which rings would effect this sorry but yes the do move easily, well mine did anyway,
mabey roland or one of the other guys know which one it would be, you say its the only change you have made, so it must be that mate, give roland a phone mabey he will know.
0118 375 9464
cosmic023
Rob:
Yeah still no joy, but i'm workin' on it.
I think i will give Roland a call (If he's there ??) as i got the PJ from him in the first place.
Typical 'tho as i start to venture inside, thing's start to happen that are not needed !!
Gremlins they get everywhere !! :D
Cosmic023
cosmic023
No viruses here rob !! :D
Just been on the blower to [email protected], and i moved the blue yoke back from the bell of the tube.
Once pushed forward, resets the blue image to almost where it should be !!
Well in my state of panic, i reset everything to midposition.....so i'm going to have to do a full set-up again !! :(
But at least i learnt a lesson here !!
Cosmic023
rob12770
thats good, its a nightmare when the PJ messes up, ive been there too mate, havent we all. glad you got it sorted :smashin:
cosmic023
Thanx Rob:
Yeah, still learning me way round this complex beast. I do have basic skills in electronics, and do basic repairs in most appliances.
So those skills come in handy.
Cosmic023
Roland @ B4
Pulling the yoke back from the bell of the tube will make the image bigger. It will also cause the tube to heat considerably.
