Blue streaks
Discussion in 'LCD & LED LCD TVs Forum' started by Eggman1972, Feb 12, 2009.
Tags:
  1. Eggman1972
    Eggman1972
    Hi peeps got an LG37"3000 & on lights etc i get blue trails coming from them adjusting contrast & brightness helps as does messing with the expert settings in the menu..My settings are as follows Fresh contrast is off NR off Gamma High & Black level low..Back light is 90 contrast 75 brightness 40 sharpness 50 colour 45..
    any got the optimum settings for the set or is this set faulty ??? thanks in advance..i have attached 2 photos
  2. TomStamp
    TomStamp
    Feb 13, 2009
    211
    +8
    First post, felt the need to join just to reply to your post lol, Yeh well I think its a fault, a few weeks ago I bought I think the model is lg lc56 not sure anyway had lines exactly like that only one of them in the midle of the screen. I couldn't decide what it was maybe a stuck pixel, I used J screen fix which helped a little but it was really annoying so I took the Tv back to richer sounds and you couldn't see it at first but they took it back no problem and exchanged it for the 3000 model so its all good.
    I recommend you try Jscreen fix or UD Pixel search these on google see if that helps, looks like its pretty significant so mayeb return it if its still under warrenty hope you get it sorted let me know how you get on :)
  3. rob426
    rob426
    May 5, 2008
    3
    Edinburgh
    What is the source material, ie.
    Is it a dvd ? if so r1 or r2
    Is it a blu-ray ?
    or sky ?
    and connected via hdmi or scart?
