Blue screen
Discussion in 'Desktop & Laptop Computers Forum' started by Jazz Monkey Jr, Jun 8, 2005.
  1. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Help!
    My main PC keeps crashing, seems to be OK when just using word etc.
    It come up with win32.sys address: BF837815 base at BF800000
    I have Athlon XP2800, 1024MB DDR400, 350W PS, Win XP Pro, Geforce Ti4400.
    Do I need to wipe it?
  2. bigtim
    bigtim
    Apr 5, 2005
    844
    28
    Cardiff
    +60
    Probably not.
    You could try going back to your last restore point to see if that fixes it.
    Otherwise it sounds likely to be either some badly seated cards/memory in the case or the PSU is on the way out.
    Try each of the above suggestions (first 2 are free, last will cost you maybe £15) before you go to the extreme of wiping it.
  3. mjn
    mjn
    May 24, 2001
    21,892
    Herts, England
    +9,597
    I'd test the memory first, with memtest+.
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Get yourself a drive imaging package like Norton Ghost or Acronis Trueimage. Next time you get a bluescreen its a 10 minute job to restore a stable boot disc.
  5. mjn
    mjn
    May 24, 2001
    21,892
    Herts, England
    +9,597
    Not going to make a difference if he has got faulty hardware......
  6. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Thanks for the sugestions, will try them out
