Blue Screen On PLV-30 While Watching A DVD
Discussion in 'Projectors, Screens & Video Processors' started by peopleIknow, Jul 5, 2002.
  1. peopleIknow
    peopleIknow
    Aug 22, 2000
    181
    My PLV-30 is 18 months old, and I recently changed my DVD player for a Toshiba 510. Now while watching DVD's I occasionally get a blue screen for a second or two. When the picture re-appears the projector as lost it's widescreen setting.
    It doesn't happen with every film I watch, and as occurred no more than twice during the same film.
    Anybody know why this is happening, can it be fixed ?
  2. jonny m
    jonny m
    Mar 22, 2002
    405
    The progressive blue screen prob on the plv-30's was solved in later models with a firmware upgrade I think, anychance you will need to send it back to the distributors in the uk, can't remember what they are called but your dealer will tell you.
    I used the 510 on my eiki sanyo plv-30 clone for a couple of movies and it was fine with prog scan ntsc.
    I think someone (chris frost?) posted that it was a firmware prob.
    j
  3. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    Jonny m is quite right. Early PLV30s flipped out with progressive signals when there were bright flashes in a movie. Fifth Element, Leeloo falling into the taxi was a good example.
    Check with your dealer about getting the projector sent away for a firmware upgrade.
    Regards
  4. peopleIknow
    peopleIknow
    Aug 22, 2000
    181
    1/ This problem is happening with both Region 1 & Region 2 (which is not progressive), so are you sure it the same problem.
    2/ As the projector is now 18 months hold, and so out of guarantee will I have to pay for this upgrade & if so how much is it likely to cost
  5. jonny m
    jonny m
    Mar 22, 2002
    405
    1. Is it the Tosh then?? Maybe its just your component inputs, anyway a firware upgrade will probably help.
    2. As far as I remember - Im sure chris can clarify - isn't the guarantee now 2 years? If it is just 12 months, a firmware flash shouldn't be that expensive.
    Best to get in touch with your dealer to sort out.
    Good Luck
    j
