blue pip
Discussion in 'LCD & LED LCD TVs Forum' started by killer10971, Mar 9, 2005.
Tags:
  1. killer10971
    killer10971
    Dec 29, 2004
    1,129
    +36
    just replaced my 37pf9986 due to dead pixel and thought id tryout the pip due to the posts about colour problems ie blue /pink (hadnt tried it on my previous set)
    i have now a perfect set but with pip any setting that uses a large format ie dual screen the larger image has a blue cast
    yet if i use pip 1 (the one with the adjustable little box that you can move around ) its perfect and split between ceefax and large screen is ok.
    i dont really want to send it back again as i have a perfect screen and i might get another turd as a replacement , but at the end of the day its a lot of cash even though i wont use pip probably
    anyone fixed this problem
  2. ArNx
    ArNx
    Same problem :mad:
    PiP Pink :(
    Xbox via component to Yamaha rxv2500 to TV via component = No picture. :mad:
    Called Philips :uk: today. Still waiting for answer :(
    Looks like my one will have to go back. (Hope Not :suicide: )
  3. ArNx
    ArNx
    killer10971
    how many dead pixels was on your tv?
    how long you waited for exchange?
  4. killer10971
    killer10971
    Dec 29, 2004
    1,129
    +36
    i only had one stuck green pixel roughly in the middle , i couldnt really see it but the company i got it from got funny when i mentioned it and tried to fobb me off so i got them to change it , philips were very good about it
    had to wait about two weeks , but they dropped off new one and took old away so i wasnt without a set
  5. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Can the Yammi output Progressive Scan? If it doesn't, and I bet it doesn't, you will not get a picture. The DVI input on the TV requires Progressive Scan....
    On the PIP problem, have you tried the other PIP settings? ie PIP, PIP3 and PIP6? Try these and report your findings....
    JImmy
  6. killer10971
    killer10971
    Dec 29, 2004
    1,129
    +36
    on mine the dual screen the left side has a blue colour cast , pip is fine , pip3 the large picture on the left has the blue colour cast but the small ones are ok and pip6 blue colour cast on the left side but the small ones are ok
    also contacted philips uk and am waiting a response
  7. killer10971
    killer10971
    Dec 29, 2004
    1,129
    +36
    been contacted by philips and its a fault and will have to be replaced again
  8. ArNx
    ArNx
    Not sure Yammi can output Prog. Scan (at the back 3 component in - 1 component out).Will call yammi on monday to check.
    PIP Problems on any settings :mad: , even split screen.
    Philips recon second tuner faulty :oops:
    Now waiting for supplier to arrange a swap. :rolleyes:
