Blue Picture in showshifter
Discussion in 'Desktop & Laptop Computers Forum' started by DaleC, Jun 9, 2005.
  1. DaleC
    DaleC
    I have recently bought a Sweetspot video card and have managed to get it working in DScaler without any problems.
    The problem is that when trying to use the card in showshifter i just get a solid blue picture and i can't actually see any of the tv's output.
    I've heard you need to copy some dll files into the showshifter directory but i'm not sure where i need to get these files from and what are the exact ones i need. Also, do i need to use the WDM drivers that come with the card or do i use the BtWincap drivers? i wasn't sure whether to use the WDM's as they are still in beta.
    I do have to say that the picture quality is DScaler was very good indeed and that was using S-video but that will change as soon as i get my RGB scart lead delivered.
    Hope someone can help
    Dale
  2. philipb
    philipb
    Mar 6, 2002
    2,029
    63
    Swindon
    +148
    I think you need to install the WDM drivers for SShifter to see the Sweetspot. Download them from the Plugged-in website (or they should be on the CD supplied with the card).
  3. Alex Simon
    Alex Simon
    Hi Dale
    Have you got this up and running now?
    Alex
