Hi it's like the panels aren't aligned 100% giving a very slight blue or green edge to objects - most noticeable on animated films like the Lion King. Is this to do with the DVD encoding, or can I adjust the overlay at all ? I'm using QED component leads from Sony 930. Pictures remain bright and clear, bu the effect is not apparent on the DVi input. Any ideas ? Chris
Ignore this, just tested the AE500 in the living room and it has the same effect. Been spoilt by DVI, nuff said.
