Blue Fringe on (lcd) Projected image. Bulb or LCD Panel faulty?
Discussion in 'Projectors, Screens & Video Processors' started by djg, Mar 22, 2005.
  1. djg
    djg
    Hello all. I have a Sony VPL CS2 which I have had since new. Up until now there have been no problems. It has about 1600 hours bulb time.
    Lately I have noticed that the projected image has a vertical blue fringe at the right edge of the image area. As time passes, the fringing appears to be slowly extending further into the image area. At the moment it is several centimetres wide on a (w)2m x (h)1.5m viewing area.
    I am hoping (that's 'hoping' in it's loosest application due to the cost of bulb replacement) that it is a bulb issue rather than an LCD panel issue.
    Can anyone confirm my suspicions or at least give me a clue as to the reason for the blue fringing.
    cheers.
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Unlikely to be a lamp problem, possibly deterioration of one of the polarising filters.
    Jeff :rtfm:
  3. stripe
    stripe
    Apr 7, 2004
    1,241
    Scotland
    +123
    This is a one of the more common faults on the earlier Sony CS (ie 1 &2) models, it is a sign that the LCD are on the way out.
    I used to have a CS1 and before buying it I was told to check out for any untowards blue on the screen.
  4. djg
    djg
    As I know three-fifths of sod-all about actual projector technology, is the LCD replaceable? And if so, how do they relate, costwise, to a bulb?
    Any info greatly appreciated.
  5. stripe
    stripe
    Apr 7, 2004
    1,241
    Scotland
    +123
    Unfortunately the are frighteningly expensive, and as such they really aren't worth replacing. It would probably work out cheaper to replace the full unit.
    Sorry
  6. stevietoon
    stevietoon
    Aug 11, 2009
    2
    Newcastle upon Tyne
    I've been given a Sony VPL-CS2 projector, but when I switch it on, although I do see the picture it shows a bright yellow dot in the middle of the screen.
    What is this and how do I get rid of it!!
    thanks,
    Steve
  7. swiftpete
    swiftpete
    Sep 30, 2006
    4,286
    Notts
    +693
    Read the previous posts...
  8. stevietoon
    stevietoon
    Aug 11, 2009
    2
    Newcastle upon Tyne
    Thanks, would you think the bulb is ok in it though?
    s
  9. T0M
    T0M
    Nov 15, 2006
    1,804
    +90
    Many years ago I had a similar 'blue tint' problem.
    I ordered a replacement 'blue polasising' plate from sony (£55 i think) and had a go at fitting it myself as I was happy to change the PJ if I messed it up.
    It fixed the problem and the PJ lived on.
