Blue Faces
Discussion in 'TVs' started by Adrenochrome, Jul 19, 2003.
  1. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    My next door neighbours have just got a new tv, video, dvd player, and hi-fi to add to their sky digibox and asked yours truly to connect it up for them.
    I have connected them this way
    dvd player scart to sky scart
    sky scart to tv scart rgb
    hi-fi phono to dvd phono
    Now when i have the scart going from dvd through sky the picture when viewing dvd flesh tones are light blue but fine when going directly from dvd to tv.
    To get sound through their hi-fi i need to connect it via sky digibox.
    So can anyone tell me how to get rid of the blue flesh tones??
    Adrenochrome.
  2. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    Can you try S-Vid to see if that brings an improvement ?
    Is the symptoms present with sky ? Has RGB been enabled for sky ?
  3. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    Symptoms aren't present with sky only with dvd.
    :blush: Forgot to check if rgb was enabled on sky:blush: :suicide:
    Adrenochrome.
  4. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    Have enabled rgb on sky but blue is overriding red on dvd still. I'm stumped anyone any ideas for me?
    Adrenochrome.
  5. JER101
    JER101
    Is there a problem with the DVD directly connected to the tv?
  6. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    No picture is fine when connected this way.
    Adrenochrome.
  7. JER101
    JER101
    My Grundig Digibox has the Blue and RED RGB passthrough crossed over, so problems like yours do occur. Yours would appear to be to much gain on the blue buffer/amp, which should have no gain. This is a fault and you should get your digibox fixed, or swapped to one without this fault. Alternativley you could try soldering a resistor in the DVD scart lead to reduce the blue. I doubt you will end up with a lineir result though.
  8. johnski
    johnski
    As JER101 says it looks like a sky box passthrough problem, but could you tell us the make and model of tv and dvd as if theres any problem with getting the box replaced or repaired there could be alternatives depending on the models, i'm thinking along the lines of rgb passthrough on the dvd if it has 2 scarts and using the tv as the audio switcher.
    johnski
  9. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    Thanks for the replies,
    T.V Model No Samsung ws28v53ns
    DVD Model No Samsung dvde235
    Sky box strangely enough is also a Grundig
    Regards
    Adrenochrome.
