Blue discolouration on white pictures on Panasonic TH42PV70EY
Romero
Any idea what's causing this? Is there anyway to fix it? ignore the scan lines in the photos it's the discolouration in the background.
fluxo
You probably will find something like that if you use Google image search. I'll search for you, if you wish, when I'm back on my desktop machine.
You're not going to be the only one with something like this and I've seen something similar myself on two displays in Sainsbury's. AVSForum is another good place to ask for help.
If you're lucky, it's just in need of a voltage adjustment or something that has come loose needs reconnecting. But my guessing isn't going to be very helpful for you.
Good luck, anyway.
