blu ray
Discussion in 'Blu-ray & DVD Players & Recorders' started by hookstar, Sep 9, 2007.
  1. hookstar
    hookstar
    Jul 6, 2007
    9
    dose anyone know if they have manged to hack the blu ray side of the samsung BD P-1000 ie take the blu ray region code to allow you to playy imported blu ray movies.
    thanks if any one can help
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    No that I have seen and I doubt we will see this either, you need to pick a region and stick with it, supplemented with the additional region free discs like those that have been issued by Paramount and Warner.
  3. Pecker
    Pecker
    Dec 26, 2004
    22,487
    Huddersfield, People's Republic of Yorkshire
    +4,608
    Or buy 2 players.
    I'm not being flippant, that will be a real option for some.
    Example, if you buy a US PS3 and a UK Sammy dual-format player (or vice versa) you're covered for R1 & R2 SD DVDs and RA and RB Blu-ray Discs.
    Oh, and you can play HD DVDs, too. Not a bad set up. And you might be able to pick that up for less tha the cheapest BD player (or for that matter the cheapest DVD player) would have cost you at launch.
    Steve W
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    Put a Pioneer 202 (£140) Blu-Ray drive in your PC along with an ATI 2400 (£30) graphics card and play any region you like. You might need powerDVD Ulta (£50) and maybe AnyDVD HD (£15) to play them.
    Less than £250 for multi region!
    (add a Xbox 360 HD-DVD addon at £100 and have multi format, multi region for less than £350)
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    assuming you have a pokey modern PC with plenty of memory that is capable of this or a machine that is capable of an upgrade.
