malcky
Hi folks,
Im looking to get a player that has both hdmi and component outputs and the LG bd550 has this, however I dont know if they output at the same time or if in the menu settings you have to choose which output is used or not???
Reason i ask is because i will use the hdmi to my projector and the component outs to my tv but dont want to have to swap setting all the time to use 1 or the other.
Also, does the upscaling only happen if using the hdmi output or with it upscale on component too?
