Blu-ray player HELP!!
electrifier
Hi people
I need some help :lease: with my home theater setup.
Equipment concerned with this problem is:
TV:
Samsung 3D LED tv :thumbsup:
Model: UA55C7000WF
A/V AMP:
Sony multi channel av receiver
Model: STR-KM7500
BLU-RAY Player:
Samsung
Model: BD-C6900
My problem is when I connect the blu-ray player to the tv via the amp, the amp doesn't seem to want to pass the signal to the amp output which is connected to the tv, of course. I also get no sound from the amp. When I connect the blu-ray player straight to the tv it works fine but I get no sound from the amp.
Blu-ray to amp cable is HDMI
amp to tv cable is HDMI
Is there a setting i've missed? A compatibility problem?
Any ideas :lease:
davepuma
It could be a resolution issue so I would try altering the resolution when connected to the TV then connecting it back via the amp. The fact you aren't getting video or sound does sound like a source or cable issue. Have you tried swapping cables or inputs? Does the amp work with other HDMI sources?
electrifier
Hi davepuma
Yes I swapped inputs, problem still there & the cable i'm using is the same one that works when connected straight to the tv. Yes, my Tivo box is connected to the amp with a HDMI cable & it works fine.
I changed the resolution on the blu-ray player from "auto" to "1080p" and reconnected it through the amp and what do you know, it works.
thanks for the tip davepuma
