Blu-Ray player and Ghosting
Discussion in 'Blu-ray & DVD Players & Recorders' started by Blue.Rocket, Jun 12, 2009.
  1. Blue.Rocket
    Blue.Rocket
    Aug 20, 2005
    711
    Breckland Norfolk
    +26
    Just set up my Panasonic DMPBD60, audio is good but the visual is bad.
    I have the player connected via Optical and Component, but it shows ghosting.
    I have tried various discs but its still happening.
    Any ideas please.
  2. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,943
    Hi. :)
    I would check your TV's settings,make sure all enhancement featues (NR etc) are OFF.
  3. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    It depends what you mean by ghosting.
    If it's static "echoes" of white lines to the right or left of objects, then this will be your Component video cables. You need better (and preferably shorter) ones.
    Or if you mean motion after-images, make sure all the noise reduction controls on the TV (and the player) are off.
  4. Blue.Rocket
    Blue.Rocket
    Aug 20, 2005
    711
    Breckland Norfolk
    +26
    Have not made any changes to the TV settings but did make some changes to the DVD player settings, switching off the HDMI and setting the Component to 1080i, the ghosting has gone but the picture quality is crap, i just wondered if its because of the DVD ( Knights Tail) is an old version....although most of my DVD seem to performing the same with bad picture quality...
  5. Blue.Rocket
    Blue.Rocket
    Aug 20, 2005
    711
    Breckland Norfolk
    +26
    I am using very good quality cables, Ghosting appear around images like a shadow effect, mainly left, has gone since making changes to player settings throught the setup on the remote.
    Seems wierd when last using my Pioneer dv696 via component i had no problems with picture quality on my older DVDs....
  6. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,943
    Some DVD's can look a bit rough i'm afraid especially when you get used to Blu-ray.
  7. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,064
    Does this also happen with Blu-ray discs or just DVD's ?
    AVI
  8. Blue.Rocket
    Blue.Rocket
    Aug 20, 2005
    711
    Breckland Norfolk
    +26
    Hi Avi.
    After making the change in setup settings on the Blu-ray/DVD player, I went off to rent a new DVD, Benjiman Button, played it and picture looks great.
    My only concern is that playing some of my older DVDs such as knights tale, The Shadow etc, the quality is crap, very pixalated for want of a better word,..
  9. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,064
    Hard to say what the cause may be without seeing the issue first hand. Out of interest what display are you using ?
    AVI
  10. Blue.Rocket
    Blue.Rocket
    Aug 20, 2005
    711
    Breckland Norfolk
    +26
    Yes i understand, but its like looking at a bad video, a lot of noise, as with the new dvd its smooth...,
    not sure what you mean?
  11. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,064
    What model of TV ?
    AVI
  12. Blue.Rocket
    Blue.Rocket
    Aug 20, 2005
    711
    Breckland Norfolk
    +26
    Opps sorry.
    Sony Bravia KDF-E50A12U.LCD
    after much playing about with, it seems its the R1 discs that are the main problem with the ghosting, there is a small humming noise from the player, its almost as if its conflickting with something, such as another input........
  13. Blue.Rocket
    Blue.Rocket
    Aug 20, 2005
    711
    Breckland Norfolk
    +26
    After an intense search on this forum, i was able to discover a fix from dj uk, and it works...
  14. NICMAC
    NICMAC
    Mar 11, 2007
    426
    +17
    Hi, any chance you can let us in on this fix?
  15. Blue.Rocket
    Blue.Rocket
    Aug 20, 2005
    711
    Breckland Norfolk
    +26
    Sorry i should have mentioned that the problem was fixed via my TV and not the player, its all about upgrading the firmware on the TV.
    You can view the fix from dj uk , HERE just scroll down the page till it appears, its the 9th entry down.............
  16. NICMAC
    NICMAC
    Mar 11, 2007
    426
    +17
    Oh, I was under the impression that the issue was with the BD60, at least you have fixed your problem now....enjoy!
  17. Blue.Rocket
    Blue.Rocket
    Aug 20, 2005
    711
    Breckland Norfolk
    +26
    Yes this was my first thought as my SkyHD and other gadgets were working ok, until i found a subject on ghosting on my type TV, got to it in the end...
