Blu-ray Player Advice Please
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kclman, Jan 10, 2012.
  1. Kclman
    Kclman
    May 28, 2006
    97
    +3
    I am looking for a Blu Ray player with 5.1 analogue outputs and that can output HD audio through them that has decent BM.
    I will be connecting it to a Naim AV2.
    3D is not a requirement, It will be mostly used with a 1080p Projector, 2 HDMI outputs would be handy as the other would be used to feed a 720p TV.
    Current or second hand.
    Thanks.
  2. scottthehat
    scottthehat
    Jan 6, 2012
    11,161
    2
    167
    honiton
    +2,799
    forget that no longer available.
    BDP-93 but its not cheap.
  3. Kclman
    Kclman
    May 28, 2006
    97
    +3
    I was originally looking at the Oppo but I figured as I didn't need 3D support I'd see if there were any alternatives.
  4. jwsg
    jwsg
    Dec 13, 2002
    419
    43
    +130
    The Oppo supports 3D as you would expect any non-base-model player to - it's not a reason to choose or avoid though. You wouldn't need dual HDMI if your amp is analogue only (esp.if audio only) though once again there's no harm having it.
    Assuming the AV2 is not performing HD decode and DAC it's likely the audio performance of your system will hinge on the choice of source and therefore I'd be surprised if an Oppo wouldn't appear on your shortlist.
