Blu Ray Picture Big Disapointment!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Nobber, Apr 26, 2007.
  1. Nobber
    Nobber
    Nov 29, 2001
    321
    I have a Sony VW50 connected to a HTPC I downloaded some HD clips from the microsoft site (1080) they look fantastic! however when I connect my PS3 to the VW50 the picture (Night at the Museum and Black Hawk Down) don't really look that much better than a standard DVD!?!? not even close to the High Def clips
    Is anyone else dissapointed with the picture from the PS3?
  2. kingofironfist0
    kingofironfist0
    Apr 26, 2007
    42
    ps3 is a jack of all trades master of none
  3. nil102
    nil102
    Dec 14, 2005
    869
    43
    +95
    Planet Earth is stunning in Blu-Ray through my PS3 and Toshiba LCD.
  4. CarlB
    CarlB
    Jan 8, 2001
    1,358
    Cambridgeshire
    +282
    PS3 is a superb Blu-Ray player in my setup, easily on a par with the picture quality of my Toshiba XE1 HD-DVD player. I run both at 1080p.
    Make sure your PS3 has (at least 1080i) selected in the display options. If you have 720p selected, then the player downscales to 480p on output for Blu-Ray discs.
  5. sdb123
    sdb123
    May 17, 2005
    18,183
    2
    Rushden, Northants
    +2,255
    What resolution output do you have your PS3 set to?
  6. mallet
    mallet
    Dec 20, 2002
    191
    +20
    If you can't see the quality, the problem lies in your set-up.
    There is no conspiracy, no big secret, PS3 Blu-Ray really is very good indeed.
  7. nil102
    nil102
    Dec 14, 2005
    869
    43
    +95
    XBOX 360 owner? I think so
  8. CarlB
    CarlB
    Jan 8, 2001
    1,358
    Cambridgeshire
    +282
    Hey! I also own an XBOX360. :D
    I spliced together (roughly) this image, with one side showing the PS3 set to output 1080p, and the other set to output 720p (but actually downscaling to 480p due to the PS3 firmware):
    [​IMG]
  9. Nobber
    Nobber
    Nov 29, 2001
    321
    Just been checking, output is 1080 ok quality is better than normal but its not as good as the high def clips, still dissapointed
  10. smokedog
    smokedog
    Aug 4, 2005
    3,046
    103
    +411
    I used to own a HD-Drive for my 360 but sold it as I just didn't watch movies more than once. The picture quality on it was impressive, recently watched Casino Royale on the PS3 and I have to say the picture quality was on par with the HD-Drive.
    But I'm wearily of most Blu-Ray movies as they are badly encoded.
  11. inzaman
    inzaman
    Dec 16, 2002
    8,013
    Derby
    +1,076
    Thats a pretty amazing demo, i imagine to actually see the screen as opposed to the pictures theres an even bigger difference.
  12. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,498
    Chesterfield town of the crooked (Spire)
    +72
    what a bizarre statement :boring:
    i won't go into detail however quality oozes out of every orifice of the ps3
    just for the record the Blu-Ray playback is simply stunning, if it isn't on any setup then the problem lies with said setup not the capability of the ps3
  13. Nobber
    Nobber
    Nov 29, 2001
    321
    thansk for the posts/comments
    I am projecting the image onto an 8' Screen and my point/query is
    I play a high def clip and it is fantastic, I play my only 2 blu movies and its better than standard DVD but not as good as the high def clips, same projector same cable same screen, the only difference is the PS3 and the source Blu ray, I believe the PS3 is setup correctly and my projector says it is receiveing 1080
    so has anyone done played the high def clips from Microsoft and then a blu ray through the PS3, if so can you see any noticable differerence
    thanks
  14. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    Maybe something to do with the way the HD demo clips are filmed (mostly with an Imax camera)? they will no doubt look better than any standard hd movie you purchase.
    One good exampe of this for me is that I own a normal DVD of Super Speedway, which is an Imax movie, its looks a lot better than all my other dvd movies.
  15. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    have to say that the ps3 PQ is very very good
    cant say what the problem is but its not the bd or ps3.
    General quality of BD is now much better than the early ones that came out
  16. Sunshinewelly
    Sunshinewelly
    Dec 1, 2005
    5,084
    +467
    i also have to say that the quality of the ps3 blue ray is absolutely sublime on my AE1000.
    i am also a happy xbox HD-DVD owner.
    lets be honest here every ps3 blue ray review i have read has always praised the capability of the ps3 blue ray player.
  17. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,064
    I have a PS3 connected to a 1080pj (not a Pearl). The image from PS3 BD is good on the whole. Maybe the particular BD titles are not best suited to Pearl's dynamic iris. I've watched a couple of titles on a Pearl that looked really poor due to this. Try a different iris setting or turn the DI off to see if it makes a difference. :)
    AVI
  18. britco
    britco
    Sep 24, 2004
    187
    +3
    i have my ps3 running 1080p on a 1080p sharp 42xdie lcd tv & picture quality is superb...fantastic4 on blu ray looks almost 3 dimensional...ps3 rocks...i hardly use my 360 hd dvd anymore
  19. Nobber
    Nobber
    Nov 29, 2001
    321
    Hi Avi, I'll try the DI and see if it helps
    thanks
    Nobber
