blu ray on linux
Discussion in 'Computer Software & Operating Systems' started by vinnyemmery, Dec 29, 2006.
  1. vinnyemmery
    vinnyemmery
    Dec 8, 2006
    55
    hi i have read that by running linux you can play pal dvds
    what about bluray does this also work with region coded blu ray too as i have a jap machine
  2. m1ket
    m1ket
    Aug 24, 2005
    3,694
    UK
    +332
    i believe you need player software (to even play them never mind play a different region) and at present they need a decryption key that is licenced from the bluray group so i doubt we will see a linux player any time soon, the discs have 3 layers of encryption/protection aswell
    having a jap machine is the same region as the US so you can get discs from there aor somewhere like www.movietyme.com, the uk bluray prices are too expesive to concoder at this point in my opinion anyway
