I've run into a couple problems ripping Blu Rays to m2ts to stream to my PS3/Xbox 360. Space is no issue, just want perfect quality rips (minus the HD soundtracks). So I've started with Transformers, used BDinfo to find the right playlist on the disc, used TSMuxer to pull out the movie into a single m2ts file. The resulting file has a couple problems:
The strangest one is that while it plays back fine in WMP 12, playback in Cyberlink PowerDVD 10 is choppy/juttery in any panning scenes. This is super noticeable in the credits too. Almost looks like it's being transcoded or something.
Another annoying problem is that I can't fast forward or rewind the file, although I can navigate the timeline via the slider at the bottom of both programs. Besides that, I can't get chapter support or subtitle support, despite the fact that custom chapters are enabled in tsmuxer with the playlist I selected. As far as subtitles, 3 streams are "Presentation Graphic Streams" in english, so using trial and error I ripped 3 videos using one of them in each video. None of them appear to have subtitle support in either WMP 12 or PowerDVD. Any ideas? Help is greatly appreciated!
*Update:
While working on this, I've moved on to Transformers 2, which uses DTS HD instead of Dolby TrueHD. Even though I've checked the box to downmix to regular DTS, it appears that the audio won't play in WMP 12 even though it plays in PowerDVD. So right now my options are to play in PowerDVD with audio, but choppy video, or play in WMP with no DTS support. Any way to convert DTS to Dolby?
*Update:
