Blu-Ray Files?
beezer123
I don't know whether this sounds stupid or not, but here goes.
I've searched the forum but couldn't come across anything about this.
Is it possible to download a blu-ray film file onto a hard drive then play it on a PS3?
in the same way you would play a film on a PS3 using the correct file type.
Would it work and if so would it still be blu-ray quality?
Matt306
Technically the PS3 can play back AVCHD files from a USB storage device, so it's possible, there might be some limitation os file size though.
I have seen an AVCHD video copied onto a Dual Layer DVDR and the quality is very good.
Indiana Jones
The PS3 will only read external HDD's that are FAT32 formatted which limits you to files of 4Gb so you wont be able to rip a Blu-ray to a single file and play it even if it supported them raw.
stuart1976
If you saved the Blu-Ray file to your PC Hard Drive and then stream it to your PS3 this will get around the 4GB file limit.
I've done this with a couple of movies and the picture quality is the same, as far as I can see anyway.
bodas73
What software are you using to rip the Blu-ray files to your HD? As this would be the approach I would prefer to use:thumbsup:
Indiana Jones
AnyHD will rip Blu-rays and HD-DVD's to your HDD.
antraf1982
This is thread related although slightly expands on its remit.
I have already "Backed Up" my Blu-ray movies to my computer currently as ISO's that have been passed through AnyDVD.
If I mount the ISO then share the Virtual Drive will the PS3 play the native Bluray disk or is there a way to without having to convert the fileformat somehow?
Thanks in Advance!
