Blu ray audio formats
Discussion in 'Playstation Forums' started by gperkins1973, Jun 9, 2009.
  1. gperkins1973
    gperkins1973
    Jun 3, 2008
    1,036
    48
    Sittingbourne
    +40
    Hi there,
    Hooked up the PS3 last night and I am pretty impressed. Got it going through my Onkyo 876 and it does sound great.
    I know that you don't get the little sign on the amp saying what audio format it is but how do you know it is actually playing say DTS MASTER AUDIO or do you just take the PS3's word for it.
    cheers
    Graham
  2. Big_Si_Owen
    Big_Si_Owen
    Sep 30, 2008
    1,214
    63
    Royston, Herts
    +239
    Because the decoding is done in the PS3 it will be passing the audio to the amp in LPCM and so the amp will just show Multi Channel Audio.
    If using a standalone Blu-ray player you can set it to Bitstream and the amp would then do the decoding and display the appropriate audio format.
  3. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    Can't remember the exact button on PS3 remote for sure as i use a Harmony remote/IR dongle for my PS3 but iirc press the select button to bring up the info screen when playing a movie.
    At the top of the screen it will tell you the Audio codec. Watching Band of Brothers through my Onkyo 606 last night displaying PCM Multi the PS3 info screen said DTS HD-MA :smashin:
  4. sykotik
    sykotik
    Sep 8, 2008
    7,052
    co. durham
    +2,245
    or display on the blu-remote....
    like i said yesta mate you will be getting hi-def sound :smashin::smashin:
    so dont worry
    what speakers are you using ...if you dont mind me asking ?
    andrew
  5. gperkins1973
    gperkins1973
    Jun 3, 2008
    1,036
    48
    Sittingbourne
    +40
    Hi mate,
    I have Monitor Audio RS6's for fronts, the RS centre and RS5's for rears and yes what for it........
    SVS PC ULTRA SUB!!!!! :eek:
    Big bad ass mo fo of a sub. With the Onkyo 876 it sounds the nuts even at reference level!!!!
    cheers
    Graham
