Blu-Ray all in one choice
johny1980
Looking for an all in one 5.1/7.1 blu-ray setup.
These are the systems i am considering so far;
SONY BDV IT 1000
Exclusive preview of Sony's BDV-IT1000 Blu-ray system, featuring world's slimmest speakers | Home Cinema Choice
dabs.com - Sony BDV-IT1000 Blu Ray HomeTheatre (BDV-IT1000)
Love the looks but its very expensive and not sure it will have the sound quality ?
LG HB954PB
LG HB954PB 5.1 Blu-ray home cinema system LG HB954PB LG HB954PB
player review here;
Review: LG HB954PB Blu-ray player
SAMSUNG HT-BD2
Samsung HT-BD2 Blu-ray system | Home Cinema Choice
£700-£800
SAMSUNG HT-BD2ER
SAMSUNG HT-BD2ER Home Cinema System 5.1 system Blu-ray: Amazon.co.uk: Electronics & Photo
Samsungs seem to be only profile 1.0 which is the only downside
PIONEER LX01
LX01 Pioneer Home Cinema System - Audio - Video
again looks good but expensive and only profile 1.0 at that price !!
Any thoughts on any of these systems ?
Is there ones ive missed available or upcoming ones ?
kingfats
Hi. :)
What is your maximum budget if you don't me asking? also,does it have to be a all-in-one system as well.
johny1980
Hi. :)
no doesnt have to be all in one but im on a tight budget for separates
was only really wanting to spend £700-£800 and the LG one had caught my attention
however, for the right kit i might be willing to spend around 1k
id considered separates but it was always decent 5.1 surrounds that would eat into the budget
the all in ones also seem to look that bit more 'classy' and as the kit is goign in the new living room i was wanting it to have a good luck. separates i liked just seemd to mismatch
however, i am up to suggestions
need;
blu-ray palyer - preferably with profile 1.1 or 2.0/ethernet ?
5.1/7.1 speakers and amp with a good quality sound and look good - i dont like the really small separates and quite like the thinner tallboys
either on amp or blu ray would like a usb slot
kingfats
I mean with a max budget of a grand you should be able to knock up a decent setup i reckon :smashin: first step would be the player,what about the Panasonic BD35 for about £150?
New model BD60 (£200) allows DivX over the USB.
Then maybe you go with an amp (HD audio) then speaker package?
Depends on what you want really there's a ton of choice out there.
kingfats
RottenFox
kingfats
Sorry :( i'm unfamiliar with Sky.
All the players are fine of course,if concerns over an amp then ask in the receivers forum your soon get the info.
EDIT:Ah,:D i see RottenFox has sorted it out.
