Blown Yamaha RXV3900
Discussion in 'AV Receivers & Amplifiers' started by gaz847, Aug 2, 2012.
Tags:
  1. gaz847
    gaz847
    Dec 24, 2006
    416
    Dorset
    +7
    My son has kindly cooled my RXV3900 down with a mug of water!
    So I am now on the lookout for a replacement. I was hoping for some recommendations if possible. It will be paired with a Monitor Audio RS6 AV 5.1 speaker package with Chord speaker cables ( fronts are bi-amped as a feature of the old amp). I run Sky HD and a PS3 through it.
    Any thoughts would be well received, looking to spend £1500 ish (or less).
  2. Andrew K
    Andrew K
    Oct 14, 2004
    3,392
    +608
    Yamaha RX-A3010 would be my replacement. There are new models coming out in a couple of months as well.
