Blown speakers- advice needed
Discussion in 'Home Cinema Speakers' started by Duncan, Jun 11, 2002.
  1. Duncan
    Duncan
    Using a Yamaha DSP-A1 and Episode 1 I had the following speakers blow their tweeters during the podrace sequence:
    B&W CDM7 Left Main
    Kef 34ds Left Rear Surround
    B&W CDM Centre
    Seeing as the speakers rate well above the Amp I am a bit annoyed that this has happened- plus I am reluctant to take them back to the dealer at once. This being unsure as to what the attitude to 3 different speakers blowing at once would be (Dealer being Sevenoaks Sound and Vision in Greys Inn Road).
    All are under warranty and are only about 18 months old- I have live with this for a few months until I saw Darrens post.
    Am quite prepared to pay for parts (within reason!) if my warranty doesnt cover this- any advice on how I might approach this.
  2. Jase
    Jase
    Mar 16, 2001
    10,804
    United Kingdom
    +2,693
    You wont know if they´re covered by the warranty unless you take them back. Kef normally replace drivers without problems, not sure about B&W.
    You can only ask. If they´re not covered by warranty just get them to order the relevant tweeters/drivers and pay for them.
    Dont know what level you were running your amp at but the Kefs can withstand very high levels without problems.:confused:
  3. Duncan
    Duncan
    Thanks for that- am feeling a lot more confident now!!!
    Cheers again.
  4. GaryG
    GaryG
    Duncan
    You have my sympathy! Faulty equipment blew the tweeters in my KEF Ref 4's three times before I finally got fed up and sent it in for repair.
    With regard to the KEF speaker it's most likely that you've blown the tweeter in one or both of the Uni-Q drivers no great shake at about £18 a piece, + labour of course!
  5. Big Jim
    Big Jim
    might it be worth getting the amp checked out to see if it is faulty? Yamaha should pick up the tab if it was their kit that caused the problem. Let us know how you get on.
