Blown speaker?
Discussion in 'Home Cinema Speakers' started by matblack, Apr 11, 2005.
  1. matblack
    matblack
    Jul 30, 2003
    404
    +10
    Hi guys, I just noticed that one of my rears seems to have lost its bass cone :(
    Its a Kef Coda which I got cheap from RS a year or so ago so its no great loss and I might even relegate the working one to a 6.1 mid rear and replace the Q30s with Refs then move the Q30s to the back. However I wondered if there is a short term cure without replacing the cone?
    The bass cone is reluctant to move when pushed with a finger and makes a quiet grinding noise :(
    Also I was wondering why this might have happened? I've heard of tweeters going but not bass, what tends to be the issue behind this?
    MB
  2. Cliff
    Cliff
    Mar 17, 2001
    4,688
    137
    Kent & overseas
    +1,836
    That is very unusual. I would phone KEF. They will probably replace it for a very nominal charge.
    Reasons for this type of fault?
    1) Playing too loud
    2) Amplifier fault- DC through voice coil
    3) Magnet assembly loose fouling coil
    4) Heat/humidity on cone distorting shape
    5) Spider becomes unglued
    6) swarf/ dirt in gap
    Enough to be going on with?
    Cliff
