Blown CC6 Tweeter
Discussion in 'Home Cinema Speakers' started by chrisw, Oct 18, 2005.
  1. chrisw
    chrisw
    May 20, 2004
    2,419
    83
    Maidenhead
    +263
    I think I've blown the tweeter on my B&W CC6 S2 ... not too sure how, but the only sound coming out is through the two main drivers - nothing through the tweeter.
    Can this be repaired, and if so how much would it cost?
    It's matched with 2 603 S2s at the front - would I be better off getting rid of this and getting something slightly better. If so what?
  2. Jase
    Jase
    Mar 16, 2001
    10,959
    United Kingdom
    +3,421
    Usually a doddle to change Chris and they're not normally expensive. I've had couple go on both Kef and M&K speakers and they were only about 25-30 quid each. Alternatively, you could use it as a good excuse to change the Centre speaker. :) Maybe something a bit beefier from B&W.
