B
Bugblatter
Yep, the moment we all dread happened tonight, the bulb blew. Only thing is I've only had this projector a little over two months. On the plus side the bulb's still under warranty, and the minus side if this is the life I can expect from these things then the pj will cost me £150 per month to run!
Now I've been using it a lot, as a TV-replacement, but it was still a little under 500 hours (and most of that was in economy mode). Now if it had lasted 2000 hours as rated then it would have lasted me 8 months, which I could live with.
Anyway here's my mail to BenQ, which includes links to the threads on AVSForum discussing this issue:
Hi. I bought a PE7700 from ivojo,co,uk a couple of months ago. Unfortunately the bulb just blew, fortunately it's within the 90-day warranty period.
I'd be grateful if you could advise me of the procedure for obtaining a replacement bulb.
I'm also very concerned about the lifetimes of the bulbs. This one has only lasted a couple of months, which means that once the bulb-warranty expires this projector is likely to cost me over £150 per month to run!
That's if I can find anywhere with them in stock, I've only found one site that lists the bulbs and they have no ETA on stock.
A little research has shown me that I'm not alone in having this problem. Check out these threads on the well-known AVS forum:
http://www.avsforum.com/avs-vb/showthread.php?t=576422
http://www.avsforum.com/avs-vb/showthread.php?t=579808
If you click on "Show Results" in both threads you'll see that the poll gives extreme cause for concern. Admittedly these polls can be skewed, but even if that plays a large factor the results are so bad that there's clearly a serious problem with the bulbs.
Incidentally the projector was generally run in "Economy" mode.
I'd be grateful if you can firstly advise me of the procedure for obtaining a replacement bulb and secondly let me know what's happening with these bulbs. For example was there a manufacturing defect that has now been eliminated?
Many thanks,
Many thanks,
