bloomi'n choices
Discussion in 'AV Receivers & Amplifiers' started by John Watts, Feb 11, 2001.
  1. John Watts
    John Watts
    Jan 27, 2001
    3,961
    71
    Leeds
    +80
    Can you believe it,just as soon as i decide that im going to buy the denon 3801 and talk to Jeff and others about it then up pops the chance to buy a yammy AX1 for £1000 what should i do folks?,is the yammy worth the extra money or is the 3801 as good? i know the yammy has music limitations but i hear it is the king with movies-help me im in amp turmoil
  2. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    967
    Scotland
    +18
    As an owner of the AX-1, I'm curious to hear what you heard about it's "musical limitations".
    I have just plugged in my Cyrus DAD3Q-24 CD player and although the bass is not quite as controlled as with my Cyrus amplification, the Yamaha does a more than adequate job of reproduction. I would guess however the lower the spec of the input component the worse it will sound.
    For example when I use my Toshiba SD200E for CD audio it sounds crap [very poor bass control], and I wouldn't expect any DVD player under £500 to do any better.
    As in most things, you gets wot you pays for
    Put the bunny back in the box !
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    The AX1 is different class to the 3801, it will beat it hands down in all aspects. Sure it doesn't have DTS 6.1 discrete, but I wouldn't worry about that.
