bloody frustrated
Discussion in 'Satellite TV, Sky TV & FreeSat' started by deanz, Aug 17, 2003.
  1. deanz
    deanz
    in the last couple of weeks i have got a Philips DVDR 70 and a Sanyo 32 FWN4 widescreen telly....I also have Panasonic TUDSB30 sky digital box and a pioneer 525 DVD player....
    Both scarts on TV are RGB (according to manual),,,,ok here goes
    SKY BOX---to AV1 on TV (screened scart cable) and to AV3 on DVD recorder
    DVD recorder to AV2 on TV
    DVD player to AV2 on DVD recorder (also used a loop for watching DVD player)
    I have developed a contrast problem and i cant work out what is causing it......White backgrounds can be overbright and skylight and outdoor scenes can be almost blinding.....it cant be the TV because i had this problem with the TV the Sanyo replaced....
    Any suggestions would be very welcome because if i touch anything else the wife is going to kill me cos she has had enough of her soaps being interupted with my fiddling about
  2. Ged
    Ged
    Apr 29, 2002
    938
    +24
    I noticed my Philips 890 ups the contrast on signals passed through it, but also Sky has a contrast mode in it's set up menu, check it and lower it if neccesary.
    Ged
  3. deanz
    deanz
    thanks for advice,contrast on sky is set to low,,,however the DVDR70 seems to be the problem,I also record from other sources and the whiteness is obvious there too....any suggestions?
