Blocky Tv Picture
Discussion in 'Microsoft Windows' started by Molly, Mar 23, 2006.
  1. Molly
    Molly
    Jun 15, 2001
    212
    Lincolnshire
    I have a blackgold TV card installed on my MCE machine. On occasion the TV picture turns all blocky (large blocks flicker quickly). When I press stop and then resume, the picture goes back to normal viewing.
    Any ideas??
  2. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    Probably a poor signal or possibly a low powered CPU if you system is a roll your own. What are your specifications?
  3. Molly
    Molly
    Jun 15, 2001
    212
    Lincolnshire
    I don't think its a signal problem because it corrects itself by stopping and restarting.
    My Pc spec is a AMD 3200+, Ati 9600 and 1gb Ram?
    I have no problem playing Hi-def.
  4. Pudgerboy
    Pudgerboy
    Jan 5, 2006
    118
    what mpeg2 decoder are you usng? you could try a different one.
  5. Molly
    Molly
    Jun 15, 2001
    212
    Lincolnshire
    I'm using the Nvidia codec.
    What other codecs are available?
    Has anyone else had the same problem?
  6. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    I still suspect the DVB-T signal. Does it happen on any recordings & is it consistently in the same place? Next time it happens try rewinding & then playing back. If the blockiness is consistent then it is a problem with what MCE is receiving from the TV tuner. Make sure that you have the latest drivers for the TV card & graphics card.
