Hello you lovely audio souls, this is just a reach out for any advice for a problem I have with my Marantz PM6006 Amplifier
Thankyou in advance for any help or suggestions to resolve my issue.
I have been using a Marantz PM6006 for 4.5 years, It's connected via optical cable from a Sony Bravia TV, I just use it as a TV speaker amp and that's It and never above 20% volume, lots of air ventilation. It has a pair of Yamaha 6 Ohm floor standing speakers connected to It.
Last week, I turned it on and the red power light started blinking and a quick lookup suggests a problem with the circuit protection.
I have unplugged the speakers and the same problem manifests itself, straight to a red blinking light. now here is the weird thing, If I turn it off and on every 10 seconds, It eventually starts working fine, Is this a cap that needs charging or has leaked.
How do I feel? to be honest, I feel like throwing it in the bin and never touching Marantz again, this amp has had hardly any use and has just died.
Can anybody give me advice on what I should do, I am worried if I get it repaired, it will just do the same again.
