blaupunkt travelpilot2 Help please
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by [email protected], Mar 19, 2006.
  1. merrythorpe@mer
    [email protected]
    have just installed the travelpilot2 in my car ,tried to configer it by auto and manual but it will not work
    I have a signal from the sat. and it is picking up 7 sat ?? but will not find roads :(
    :lease: help
  2. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
    How long have you left it switched on? Some units can take quite a while to get their first fix.
  3. merrythorpe@mer
    [email protected]
    Have driven about 4miles with it set to configer and set to find a local road :(
  4. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
    Can your unit report is it's actually tracking the sats rather than just being able to see them. Are the maps you have installed actually viewable?
  5. graymar77
    graymar77
    Do you think it needs a speedo pulse cable fitted ?
    It just shows an arrow ? no roads or information
    Is a cable easy to fit on a volvo v70 ?
    thanks
  6. JMPremier
    JMPremier
    Sep 3, 2004
    145
    I installed a Blaupunkt DX-R52 in my MX5 last week and it did the same. I had to connect the speedo pulse so that it would go through the calibration, until then all it did was show the direction arrow (random wrong direction) and say that I was 'off road', once connected I had to go about 20 yards at less than 19mph (I think that just checked for a pulse) and then drive normally for about 6 miles to complete the calibration. It works great now though apat from not being able to load a safety camera poi like my garmin i3.
    JM
