Blaupunkt Cd/radio For 2002 Corsa
Discussion in 'Video Streaming Boxes & Services' started by darren787, Dec 29, 2004.
  1. darren787
    darren787
    I have just bought a Blaupunkt CD/radio which is standard fit in Europe for the Corsa/Meriva.
    The new unit came with the double din basket (exactly same as the one in the car that houses the Philips CA 2004), and the 3 ISO connectors are the same as those for the Philips.
    Unfortunately the Blaupunkt did not come with a wiring diagram or sticker of how the ISO connectors should be wired, but suffice to say that the wiring cannot be the same as it is for the Philips.
    The HU display does not work, and although I have had the Blaupunkt CD/radio working, it definitely isn't right as the steering wheel controls don't work, the HU display does not work, and the unit will not power up without the ignition being on. The only part that works with the ignition off is the flashing security LED.
    I don't think the Blaupunkt requires adaptor leads as it is GM OE in Europe, but I really do believe the order of the wires within the 3 ISOs is different to that here for the Philips unit.
    Has anyone come across this before, or know of how it can be sorted. Teh pins in the back of the unit are not numbered either.
    Any help/advice gratefully received.
  2. Crocodile
    Crocodile
    Nov 4, 2002
    18,332
    +6,859
    PM your e-mail address & I'll send you a scan of the label on the Blaupunkt 2003 radio/cassette that came out of the missus' 2001 Corsa. Don't know if it will be of any help but it's a start!
  3. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    You need to swap the positions of the switched +ve and the unswitched +ve to resolve the power up issues, from memory it's the Blue and Yellow conductors that require to be swapped.
