blanking plates
Discussion in 'Home Cinema Building DIY' started by MarkHudds, Mar 27, 2003.
  1. MarkHudds
    MarkHudds
    Jun 12, 2002
    548
    +4
    Just in the process of getting a few blank blanking plates (standard UK 1 gang) ready for mounting on the wall. As these will be used for various cable outlets (i.e. cable straight through with no terminators), I'm just cutting a 20-30mm hole in the middle.
    Obviously the cut plastic will have a sharp edge and I'm just thinking about how/what I can put around the hole to protect the cables being routed through.
    Any ideas folks?
  2. themadhippy
    themadhippy
    for standard electrical size holes(20,25 32mm)you could use rubber grommits,if the hole is a non standard size/ shape then gromit strips the stuff
