Blanking plates in non-white
Discussion in 'Cables & Switches' started by topperdoggle, May 4, 2005.
  1. topperdoggle
    topperdoggle
    Jan 4, 2004
    147
    +4
  2. Miniholic
    Miniholic
    Apr 26, 2001
    3,046
    The Shire
    +398
    B&Q do a range of blanking plates in different finishes, I plan to use these to make my own. Have a look HERE most designs have a blank available. Then it's just a case of drilling for the relevant connections.
  3. topperdoggle
    topperdoggle
    Jan 4, 2004
    147
    +4
    Interesting. Do you run the cable straight through or do you affix sockets to the plates? If so, where do you get the individual sockets from?
  4. Miniholic
    Miniholic
    Apr 26, 2001
    3,046
    The Shire
    +398
    I haven't done mine yet - I'm still waiting for building regs approval on the house so the cinema room/spare bedroom is a good few months away yet! - but I will be buying the rca sockets etc.. and fitting them to the blanks. I did think about passing the cable through grommets fitted into the blanks so as to save on extra connections and poorly soldered (by me :rolleyes: ) joints, but that may prove a little tricky with the size of some of the connectors fitted to the cables. I may just use plates for the speaker wires, as i haven't planned where the equipment will go yet.
    Have a look at Roguey's thread he has made his own plates using blanks.
    There are some connectors available on the nexxia site you mention, but a quick google should find some more suppliers. It is important to make sure that the connectors are insulated from the plate if you use a metal one, it would be a shame to put a lot of work in and end up shorting the connections.
