Blank screen problem on my Toshiba
Discussion in 'General TV Discussions Forum' started by carl310166, Jan 2, 2007.
  1. carl310166
    carl310166
    Hi All,
    In the last few days my Toshiba 32" has had a problem on startup, the sound is there, but the screen is black,but after a few mins, it comes on as normal!
    I think i bought it in March 03, i am not sue of the model number,but it's the "picture frame" one that cost me £1300 back then,but obviously i can find it if needed.
    Has anybody got any ideas what the fault could be?
    Will it fail totally?
    I can live with it, if it's not going to burst into flames etc.
  2. carl310166
    carl310166
    Just looked up in the manual, it's a 32 ZP38B ??? model.
  3. JayCee
    JayCee
    Jan 20, 2004
    23,629
    Lanarkshire
    +2,550
    Those symptoms could be caused by the Teletext module or the Scan Converter (DFS) module...either way it's sure to breakdown again and you need to call in an experieced TV Technician and get it seen to.
    Do a search of the forum and you will come across many posts on this model.
