Blank DVD's - quality/cost question
Discussion in 'Blu-ray & DVD Players & Recorders' started by The Don, Mar 30, 2005.
  1. The Don
    The Don
    Nov 6, 2003
    33
    West London
    I've just bought a Panasonic HDD/DVD recorder and was wondering what difference there was between blank DVD disks in terms of quality.
    Will the cheap '25 for £9.99' ones be ok, or should I go for the more expensive branded (e.g. TDK, Maxell) makes?
    What do you get for the extra money?
    Thanks for any advice.
  2. mhuk05
    mhuk05
    Jan 17, 2005
    2,708
    J6 M5
    +215
    The cost is related to the dye used.
    Have a look at http://www.svp.co.uk/
    25 for £10 isn't that cheap ;) Have a look at Taiyo Yuden for a top brand.
  3. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Discs that record properly.
    Try looking here and memorise some media codes before buying from the SVP site.
  4. the.jackall
    the.jackall
    Mar 3, 2003
    28
    Northumberland
    Very Good Advice above.I have the Panny eh95 HDD Recorder,ive used about 50 TDK 4 speed or 8 speed Top Quality and only 1 coaster,Sony`s work fine and the Panasonic own brand are also very good,on the cheap disc front the bulkpaq orange 25 spindle produced no coasters either,My panny didnt like Memorex or those white printable spindle pack discs.
    I quite fancy trying Fuji they are currently on special offer at 29p here.
    www.aprmedia.co.uk
  5. laser
    laser
    Aug 1, 2004
    924
    Hartlepool
    +28
    I'm sure the more expensive media is better and perhaps only time will tell when you try to watch an archived programme in a couple of years time and find it won't play but I've been using cheap Datawrite Red v3 4x and 8x DVD-R and have had no problems with over 200 discs. At £13.00 for 100 discs they are very good value and play in all machines I've tried.
    I think a degree experimentation is often sensible to see what works and what doesn't. But I guess only time will tell if the more expensive DVD's outlast the cheaper ones.
