Blacks on the Hitachi 7200
Discussion in 'Plasma TVs' started by Badger0-0, Sep 18, 2005.
  1. Badger0-0
    Badger0-0
    May 30, 2005
    20,582
    Spaghetti Junction (really)
    +1,921
    I'm guessing I'm going to make some people scoff here.
    But the blacks on my telly are too black.
    I have to say I've never seen this "dark green" thing that's been mentioned.
    I've set up my telly using the AVIA disc and copied the settings over to Sky, a few times.
    The blacks are too black and I can't see detail.
    It certainly does black as well as the PWD6 I saw, IMO, but without the cartoon like picture.
    Does that mean the telly doesn't do black very well, or as I suspect, the black problem on Hitachis is a load of rubbish????
    I think I've got about 1000 hrs on the clock.
    Opinions, please :smashin:
  2. stanleyntl
    stanleyntl
    Dec 6, 2003
    806
    28
    Worthing, Sussex
    +44
    I've got a 7500, and only with black enhancement set to middle do I get a black level approaching my Sony CRT.
    Set to Low and blacks are still "washed out", more so with the lights off.
    SKY/ DVD (HDMI) - blacks are passable, off-air analogue - blacks poor.
    Maybe your panel has improved with burn-in???
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Your brightness may be too low. I wonder if you've managed the setup properly in AVIA? Have you tried something simple like THX optimiser? Your set is crushing black to get the overall black level. This is occasionally a prob on Pioneers too. I guess when you bring the brightness up, you are not so black any more. I did a 5300 a few weeks ago, and found it very tricky to get the balance right, not entirely happy it's right now. I normally start talking about ISF when I run into this one, give the job to a pro....
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +625
    With the Hitachi you have a choice, they are too washed out but detail is in there a bit, or you can go much darker but there is no detail so you get a sort of black hole.
    When people talk about blacks it is only any good if you can have decent deep blacks and keep detail, this is the tricky bit.
  5. Badger0-0
    Badger0-0
    May 30, 2005
    20,582
    +1,921
    Which is why I posted :smashin: ;)
    I go back to what I said though, the dark green thing is rubbish, IMO.
    I'll have another go with contrast and brightness.
    I just knew my post would bring instant results :rotfl: :smashin:
  6. Badger0-0
    Badger0-0
    May 30, 2005
    20,582
    +1,921
    I think you're right MAW, I'm crushing black :smashin:
    I think I sort of knew this ;)
    I would think that if I up the brightness, I'll be crushing white, big time though.
    Colour has gone too high for me, also. I last AVIA'd about a fortnight ago.
    200 hours, bed in, no way, IMO.
  7. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +625
    Contrast is your white level and they shouldn't effect each other in a perfect world, however they do, so I would say get the contrast down as low as you can but still keeping the 100ire looking white, and then work on the brightness.
    I have never got the colours looking right on a digital display using Avia, they always look far too saturated.
  8. Badger0-0
    Badger0-0
    May 30, 2005
    20,582
    +1,921
    I would say so, yes :smashin:
    I have "black enhancement" set to off.
    But as I said, 200 hours bed in, is laughable.
    I had about 700 hours on the screen and couldn't even see the white bars on "needles and pins" (?).
    Everything was white, full stop.
    Keep using a disc, IMO.
  9. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Badger, unfortunately Gizlaroc is right, as I have found. It will be your brightness, it won't affect your white, or at least it shouldn't, and even if it does, not much. Give the THX optimiser a go, see if your screen will display the drop shadow. Pioneers won't, except on digital inputs, and the 5300 I was working on wouldn't show it either, nor could I get any 7th black box, no how, no way. What you will lose, when you have set the brightness to show shadow detail, is overall black level. You'll be back to grey, so you'll have to sort out which is least offensive to you.
  10. Badger0-0
    Badger0-0
    May 30, 2005
    20,582
    +1,921
    You're suggesting THX over AVIA ??? :eek:
    Interesting :smashin:
    I really don't know if I've got one mate :confused:
    But I'll have a look.
    If not, I'll sort one out and run it :smashin:
    I'll come back on this :smashin:
  11. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    I'm suggesting going back to basics with something simple, that's all. Though I'm not particularly an AVIA fan, I don't mean to diss it, just you have a specific problem, therefore a change of approach may be called for. Write down your settings before changing!
  12. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Hi MAW,
    What is a THX optimiser? :)
    And where can i get one? :)
  13. tscotsman
    tscotsman
    Dec 29, 2004
    848
    +15
    its on a THX film disc, such as Star Wars Trilogy discs.
  14. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Oh good, i've got the trilogy.
    So is it easy to use? :)
  15. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Very, the destructions are in plain English, on the screen with each part.
  16. peterakastorm
    peterakastorm
    At the moment my blacks are too black too here on my PWD8... but I haven't done any calibration, and I've only run it for about 50 hours... ordered a DVE disc, but I guess it sounds like I should get a THX optimiser too... So of I go buying the Star Wars Trilogy ;)
  17. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    The optimiser is a freebie on every THX disc. It has no wonder properties, I only suggested it cos Badger is plainly in a fix, I think Avia is tieing him in knots. Don't run away with the idea it's the be all and end all, it's simple to use, and works pretty well for setting brightness and contrast.
  18. peterakastorm
    peterakastorm
    Ok... so getting the DVE is good enough, even though it's a bugger to use?
  19. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    That sums it up, yes. If you have a thx disc, have a play with it. Do it properly later by all means. The optimiser is in the languages menu.
  20. peterakastorm
    peterakastorm
    Thanks MAW, really great help, as always ;)
  21. Badger0-0
    Badger0-0
    May 30, 2005
    20,582
    +1,921
    MAW, I'm not in a fix mate and AVIA is not tieing me up in knots.
    I think AVIA is quite easy to use, although I have a (very intelligent) friend who just couldn't understand it.
    I don't remember what the specific patterns are called, but I set the telly up so I just lose the right bar on blacks and the same on whites. I'm going from memory here, but trust me, I got it right :smashin:
    I couldn't even see the white bars on the 4th time of using AVIA (about 800 hours) and had to move back and forth(contrast and brightness) until I could.
    The settings had altered that much in a couple of weeks :eek:
    My post was more about settings changing over fairly short periods of time, even after about 1000 hours on my telly. That and the fact that the "dark green" thing on Hitachis is rubbish,IMO.
    I really do think 200 hours run in, is nowhere near enough.
    My screen is still changing, big time (for the better, I should add). Mine's 4 months old now.
  22. Badger0-0
    Badger0-0
    May 30, 2005
    20,582
    +1,921
    MAW, I just re-read your first post. I will give THX a go, although if it gives better results than AVIA, I'll be surprised.
  23. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    I've never noticed dark green on a Hitachi either! Not very black, yes. I'm not belittling your intelligence over AVIA, just it can't be right if you have this problem. If the brightness is fading that fast on your screen, it ain't gonna last 60 000 hours!
    And you are talking about 1000 hours in 4 months!! I'm just about to sell off my 1 yr old demo screen, 1200 hours!
  24. Badger0-0
    Badger0-0
    May 30, 2005
    20,582
    +1,921
    MAW, you misunderstand.
    I probably didn't explain properly.
    The reason I couldn't see the white bars was because the contrast had increased, making the background too bright (thats how I see it anyway).
    So I suppose I was getting white crush and black crush at the same time.
    If the whites are getting whiter and the blacks are getting blacker, would you say that represents a problem??
    I wasn't even thinking about it as a problem until now.
    But I did expect the screen to settle down and go into a period where things would be constant, even if only for months at a time. It would appear not and seems like it will constantly need tweaking.
    The saturation is also getting stronger, IMO.
    I wouldn't have thought 8-9 hours a day was a massive amount?
    Assuming we take your figure of 60,000, that's 20 years. Not bad, I'd have thought. Even with a half life of 10 years :confused:
    And I thought Hitachis used Alis for longevity.
    I know it's fairly early days for plasma technology, but do you have any experience in this sense? ie Have you seen any panel that has faded out/done it's lifespan??
  25. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    I've never known a panel to change that much, nor to increase in any setting. Scientifically, I do not believe there is a mechanism whereby this can happen. Brightness and contrast decrease during running in, not increase. Got any young kids???
