Blackout lining screen
Discussion in 'Projectors, Screens & Video Processors' started by scott33b, Dec 1, 2004.
  1. scott33b
    scott33b
    Aug 3, 2004
    68
    Hi. I've been looking for blackout lining to make a screen, but can only find it in 54" wide rolls. If anyone else has had this problem then check out this website: http://www.bullnet.co.uk/shops/hydro/mylar.htm
    They supply blackout lining from a roll 2m wide.
    I've just placed an order and will post the results when I recieve the material.
    cheers
    Scott
  2. scott33b
    scott33b
    Aug 3, 2004
    68
    Not what I was looking for. This is just a sheet of plastic lining.
    Does anyone know where to get blackout lining 70" wide?
  3. xavk1
    xavk1
    Aug 9, 2004
    590
    28
    +36
    I too wanted something this big, but the best I could come up with was 54". How big do you actually want to make your screen? I made it to 115" corner to corner with 54" wide, so you can go quite big with careful design.
