Blackout curtains?
Discussion in 'Projectors, Screens & Video Processors' started by Sam Darwish, Oct 20, 2003.
  1. Sam Darwish
    Sam Darwish
    Not sure if this is the right place to post but can anyone tell me where I can get blackout lining for my curtains?
  2. browsking
    browsking
    May 12, 2003
    97
    Naaaaarfolk!!!!!!
    Try a heberdashery (curtain shop)!!!!! You know 'curtain world' or something similar. Theres one in every out of town shopping centre in the uk. OK not the sort of place your average red blooded male hangs out but you could always take the missus to reduce the embarasment factor.................Should cost about £6 a metre.
  3. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Speak for yourself.................................... I reknowned for my pelmets, swags and tails :rotfl: :rotfl:
    Sean G.
  4. Markatlarks
    Markatlarks
    Jan 8, 2003
    123
    Truro, Cornwall
    Have you thought of just buying 'blackout material' cut to the exact size of the window, then fixing velcro tape to the four corners of the material, and stick the opposite sex velcro to the window frame (clear white colour works a treat).
    I have numbered my 'blinds' as some of my windows are slightly differing sizes. All you do is simply press them into service as and when required. Simple solution if you dont want to remake your curtains.
    Oh ya - 'blackout material' sells for about £5 per metre which is 2000mm wide. (Truro Fabrics in Cornwall)
  5. Sam Darwish
    Sam Darwish
    Markatlarks that would be perfect but I live near Heathrow airport (do they do mail order? Thanks), anyone know anywhere closer?
  6. browsking
    browsking
    May 12, 2003
    97
    Naaaaarfolk!!!!!!
    Hello................see my original reply. Any curtain shop will sell blackout material. There must be hundreds if not thousands in London..................................You certainly dont need to mail order from Cornwall!!!!
  7. Sam Darwish
    Sam Darwish
    I've been to a number around west London but have not had any luck! Hence my post
  8. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    I got mine from Harvey`s, if there is one near you you might give it a try.
    Chris
