Blackgold DVB-T or MCE2005 support Subtitles?
Discussion in 'Microsoft Windows' started by 9761, Sep 16, 2005.
  1. 9761
    9761
    May 16, 2005
    499
    does the blackgolds TV tuner cards support subtitles or does MCE 2005 support them?
  2. Snash
    Snash
    Sep 6, 2005
    84
    9
    From what I've seen here the BlackGolds or MCE don't support it? :confused:
    :hiya: (OcUK)
  3. 9761
    9761
    May 16, 2005
    499
    Thanks!
    :hiya: (OcUK Too!)
  4. Werner
    Werner
    mce supports subtitles via the usual teletext page ONLY IF YOU ARE USING AN ANALOGUE TUNER and the tuner is directly connected to an aerial. I believe ntl and sky filter out the teletext data, so you wont get teletext/subtitles with them.
    DVB-T cards use a totally different scheme for "teletext" data (mheg) and as such it isnt supported yet.
  5. gazzer82
    gazzer82
    Hi 9761
    The black gold card does support freeview teletext and interactive features. Unfortunatley media center doesn't, and from a source inside ms, i have been told that it has been put on the back burner as it isn't high enough priority compared to the us hd features. So i guess the uk get's shafted again for the sake of the U.S
    However, GDI the makers of the Back-Gold card are planning on releasing a piece of software that will enable the interactive features as a third party application. As of yet i am not aware of an E.T.A or whether there will be a charge for the software, but it's good to know that someone is working on it.
    Gareth
  6. 9761
    9761
    May 16, 2005
    499
    Thanks!
  7. gazzer82
    gazzer82
    No Problem.
    Gareth
