Quantcast
blackberry 9300 on talk mobile
mentos
hi all
got my daughter a 9300 for xmas unlocked,we also got her a sim from talkmobile giving her talk&txts with also 500mb data. but nowhere did it say that you could`nt just use the phone and internet without blackberry services.
is there anyway of getting this onto the net without paying the extra £5 every darn month.
thanks for any help
RobM
There is a way... but it's quite limited.
Many services like email, BBM and many third-party applications wont work without BIS (BlackBerry Internet Services), this has always been the case for BlackBerry as BIS provides the foundation of the security and data efficiency of BlackBerry. But some will work if you manually enter APN details for your network operator.
Read this: KB05327-How to set the APN settings on the BlackBerry smartphone
Then spend some time on Google finding TalkMobile APN information and enter it as described above. You may also need to change the settings of some applications to reflect the fact you're not using BIS, but that will be per-application so it's hard to advise.
Honestly though, speaking to TalkMobile to see if they offer BIS instead of standard data would be wise. Or finding an alternative provider.
Dodgy_Geezer
If it helps, I've managed to do this successfully with a Vodafone SIM in a BlackBerry that did not have BB services enabled.
If you do have BB services enabled, you can also enter the APN to access the Internet via Opera Mini without going through the BB service. This is useful for corporate devices where Internet access to personal email is prevented.
