Black & White Pictures Via Component ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by BIONIC MAN, Aug 12, 2002.
  1. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,015
    Nasa
    +45
    I'am trying to connect my Tosh 32ZD09B & Pioneer Dv05 ElIte dvd player via conponent but only get Black & White picture ? ? WHY
    The back of the player has component output which reads :
    Green / Y
    Blue / CB
    Red / CR
    The back of the tv has component in which reads :
    Green / Y
    Blue / PA/CA
    Red / PR/CR
    Will it not work as the letters do not match ? ? , also that the dvd player is a usa player with the sudo pal mod .
    So please any help
  2. marqueedehome
    marqueedehome
    Two possible solutions/problems. Either the player sends only Y/C or the tv inputs are in Y/C mode. Check from player's menu that component output is activated and in proper mode, progressive/intelaced. Also check from TV's settings the mode of inputs.
    marqueedehome
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Never heard Pa/Ca, normally YUV (component) is YCrCb or YPrPb ...
    Try swapping the leads around, can't damage anything I guess.
    BTW: what disc are you playing? R1/NTSC I assume ... ?
  4. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,015
    Nasa
    +45
    Thanks for the reply's
    I have tryed to change settings in players menu with the following options :
    RGB
    Video
    S-Video
    I have had the colours red & green , but not correct also when I connected my mates Tosh SD220 dvd player it worked fine ,
    As my player is an ntsc machine with the above connections on the back of the player , I'am thinking it will on put out the above
    signals even when it has component output on the back ? ?
