Black & White display on LG PX11 from Sky+
Discussion in 'Plasma TVs' started by midiman, Feb 10, 2005.
  1. midiman
    midiman
    Jan 8, 2005
    320
    London
    Currently have my Sky+ going direct in to my LG PX11 via S-Video on AV4 and am getting a good picture in colour. However it is a pain having to get from AV1 to AV4 as there dosent appear to be a direct key pres so have to scroll through AV1 - AV3 first. Thought I would be smart so purchased a Scart to S-Video + 2 RCA lead so I could plug into AV1 or 2 to fix this. Problem is It only comes through in black and white. Do I have a dodgy lead or do I need to set somthing up on the TV? Had a look but couldnt see anything
    PS I am using the Scart RGB out on the Sky+ to my Panasonic DMR E85 DVD Recorder which is then conncted via Component to the TV. The second AV out on the Sky+ is conncted to a Video Sender so we can watch it in other rooms. Want to utilise S-video so I dont need to keep the DVD recoreder on all the time or can do realtime dubbing from HD to DVD and still watch sky
  2. braveknight
    braveknight
    AV1 is RGB / composite via SCART - it does not support S-Video (hence the black and white picture).
    If you want to go directly to an input, the hex codes for the remote are in the manual - you just need a programmable remote (ie. Pronto, Harmony), to set it up.
  3. midiman
    midiman
    Jan 8, 2005
    320
    London
    I thought AV1 & AV2 were RGB but not AV3. The manual dosent seem to specify and all a B&W so I guess your right
    Just so happens I have a Harmony 655. Just havent had time to sus it out yet
