Black Sky+ box
Discussion in 'Sky Digital TV Forum' started by Mep, Apr 29, 2005.
  1. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    does anybody know where i can a black sky+ box, the pace box i currently have is the only silver bit of kit on my av stand...and it's really beginning to bug me........also can you just stick your card in a new box and it will work or do Sky need to be told about it?
  2. Astaroth
    Astaroth
    Jun 22, 2004
    3,653
    2
    London
    +883
    You will need to tell sky to marry the card and box together.
    I have heard of people painting their kit (which is much easier to make a silver box black than the other way round) but wouldnt do this until your 12 month warrenty is over
  3. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    many thanks....warranty is long over....had thought about painting it....but not convinced i'll do a good enough job
  4. pave
    pave
    Jul 1, 2003
    1,569
    london
    +170
    Hi,mep
    Try aerosol spray paint,pratice first on a piece of card,get a satin finish,so if you do get a few runs they will not show up too much,worth a go :)
  5. Spooksta
    Spooksta
    Nov 7, 2000
    3,311
    Planet Earth
    +717
    Dont try to do it all in one go. Give it a "1st coat" and let it dry then on the 2nd go for that "show room finnish" :D
    I do this for a living :thumbsup:
    ps
    Dont forget to take it to bits 1st :eek:
  6. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    you do?......so where are you based spooksta?
  7. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    Pave, I could do that I guess...nicer to get someone who knows what they are doing they...mind you if it's easy enough to take apart maybe it's not as i hard as i'm thinking
  8. Spooksta
    Spooksta
    Nov 7, 2000
    3,311
    Planet Earth
    +717
    From Norfolk. Not worth sending it to me m8. You will do fine im sure :)
    Unless theres a LOT of people want thier Sky+ turned Black. :thumbsup:
  9. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    ok...i'll be brave :)
  10. Bluevanman
    Bluevanman
    Paint it black, and you will not get a Sky eng to touch it again. If it ever goes wrong you will have to get it sorted out yourself.
  11. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    good point mate
