Black screen when using DVI / Scart - Please help.
Discussion in 'Microsoft Windows' started by Zarco, Jul 23, 2005.
  1. Zarco
    Zarco
    Okay i'm feed up!
    I've installed MCE and it works just fine when i hook up my Dell screen on my DVI. But when I plug in my DVI / Scart cable between my HTPC and my TV all I get is black screen. I've tryed on my laptop too with the same result.
    I've tried working with powerstrip, but no matter what I do I don't get any reaction on the TV. I'm using VNC to connect to the HTPC.
    Can anybody help me on how to connect my HTPC to my TV via the DVI / Scart on my Radeon 9250?
    Regards
    Zarco
  2. DaveP
    DaveP
    Where did you get a DVI/Scart? DVI (if it's "proper" DVI) is digital and won't work into an analogue scart socket.
    If it's wired to the analogue pins on the DVI output, you will need the special Powerstrip settings used in the VGA/Scart thread.
    Dave
  3. Zarco
    Zarco
    Okay my mistake. I'm using a vga / scart with an adapter for the DVI on my videocard.
    I have tried using the settings for powerstrip but i can't get any reaction out of my tv. I thinking that maybe i overlooked some basic setup settings. The HTPC has been used with another tv. Can it be some old settings that i have to remove before this is working?
    Regards
    Zarco
  4. DaveP
    DaveP
    I assume you are using an ATI card?
    Dave
  5. Zarco
    Zarco
    Correct. A 9250.
