Quantcast
Question Black rug suggestionss
Mr Andy
Since Ikea stopped selling the cheap black rug I've seen others use I'm looking for a cheap way to darken the floor in front of the screen. The room is 14 feet wide. Any suggestions?
sraper
Got the same problem.
Seen a few on wayfair but worried how "shiny" they might be
johndickinson
I used a local carpet & binding company. Picked out the exact colour that I wanted, told them the size and it was a perfect fit. For the size I wanted 5.5m x 3m it was actually cheaper than buying a dark rug.
Atomicus
As above, a lot of carpet shops will do this for you and can work out much cheaper than many rugs.
