Nimby
There is a craze over here in Denmark for replacing roofs with black concrete tiles (or even worse) glazed black clay tiles. The latter use much greater quantities of energy to produce compared with conventional clay roofing tiles.
Meanwhile I have been examining roofing materials which do not soak up the sun's rays.
So I had a tour round a couple of builders merchants touching displays of roofing materials with my fingertips in hot sunshine. My unsophisticated tests suggested that white pigmented, corrugated, fiber-reinforced concrete sheets are always cold to the touch. (Note: Not the cheapest uncoloured sheets which quickly discolour from original white to grey)
Most other roof covering materials were all far too hot to touch regardless of colour or the material used. I would probably have needed a digital meat thermometer to measure their temperature!
Downside? Not many people like white corrugated roofs except avant-garde architects building modern houses. Flat sheets are available in tile form but are much more expensive. These look rather like white slates set on the diagonal in use.
No amount of batt insulation will keep out the sun's heat in summer. The roof covering heats up to tremendously high temperatures and radiates straight through the insulation into the rooms within. Perhaps not a problem if the roof isn't occupied but a nuisance if it is. It would be nice if the roof surface could be "switched" to match the seasons but this is completely impractical in most cases.
Hot roofs must add to the heat island effect of tarmac roads and carparks.
Anything which reduces their absorption and re-radiation should be beneficial.
Conventional pitched roofs don't lend themselves well to "living" turf roofs.
White tarpaulins are unsightly and very prone to wind problems and rapid UV breakdown.
I considered greenhouse white-out wash for the summer season. But wondered whether it would discolour the roof permanently leaving the house potentially too ugly to be sold. The wash might not work on absorbent roof materials anyway.
Thatch is a wonderful material but far too costly for most homeowners.
Any thoughts?
Any thoughts?
